I need a design for 1MHz to 2MHz Voltage controlled oscillator for
square wave which uses op-amp. Any help is appreciated...thank you
square wave suggests using a comparator rather than op amp,
at least for the output,
a 'relaxation oscillator' is probably the best way to go,
wich is just an inverting schmit trigger with negative feedback.
the control voltage can adjust the current in the negative feedback via a
voltage dependant resistor such as a fet or
current source + current mirror + steering diodes.
its possible to do it with a ne555 timer.
Colin =^.^=
Jim Thompson said:If you want a linear control curve, beware the delay through the
comparator, 555, or whatever you use.
colin said:Theres a technique to use an inductor in series with the feedback capacitor
to make the cycle end earlier at higher frequency and so compensate for the
comparator delay.
comparator delay.
Colin =^.^=
Jim Thompson said:Nope, not an inductor, a resistor, such that tau = R*C = tdelay, and
you charge and discharge the capacitor with currents... it's NOT the
"feedback capacitor".
I think i just beat you to it with the correction at least on my news server
lol,
with a 555 type its not what you would think of as negative feedback but
with a relaxation type using an inverting schmitt trigger the capacitor is
in the lower half of the neg feedback RC divider,
and the extra resistor would be in series with the capacitor but still in
the lower leg.
of course the upper leg would be variable resistance or preferably variable
current.
using the op amp integrator type, the resistor would be in the output of the
op amp,
the triangle is still taken from the capacitor if thats what you want,
but the comparator is fed from the op amp output directly.
A picture is worth a thousand words, however I got this nugget of info from
a post in here quite some time back wich went into more detail with a nice
schematic.
Colin =^.^=
It was probably my post. I discovered that trick at least 30 years
ago ;-)
...Jim Thompson
[snip]The slickest fix I've seen is what HP did in some of their function
generators. You put a resistor in series with the timing cap.
Comparator senses the top of the resistor, but the output still comes
off the cap. As the current increases, the resistor adds more volts to
the sensed triangle, effectively reducing the amplitude of the real
triangle. Tweek the resistor for a first order correction. Helps a LOT.
Jim said:Just buy an MC4024... 3.5:1 tuning range
Here's a post from 2004 where I mention that the technique was
discussed in a previous post of mine (which I still can't locate)...
[snip add-resistor-to-555-timing-cap trick]
http://groups.google.com/group/sci....3?q=Thompson+resistor+555+delay&lnk=nl&hl=en&
Cheers,
James Arthur
Wasn't that designed by some old curmudgeon?
Yep. That's the thread! Thanks!
shame the drawings get screwed when viewed via google,
I wonder if theres an unscrew it up button somewhere.
Jim said:[snip add-resistor-to-555-timing-cap trick]
ago ;-)
...Jim Thompson
Cheers,
James Arthur
Jim said:Yep. A REALLY OLD curmudgeon. MRI next week to look at why I've
developed leg pain in my left leg only... sufficient pain to make me
limp :-(
I'll pray for you, my freind. I have swelling and pain in both legs
too, but you're the one who claims to be older than dirt. ;-)
PS, don't tell them how many parts of the MRI machine you designed.
They don't like it when the patient knows how their toys work.
