Hi Peter
In the conditioning circuit diagram the top +12V line drops down to a VMM and then a VDD before continuing to the other circuits suggested by Kris. What exactly does the VMM and the VDD connect to?
That circuit at top right is a two-stage protection circuit to protect the semiconductor circuitry from noise, spikes, and surges on the automotive supply, which is normally very electrically noisy.
The varistor is there to protect against load dump, which will occur if the battery becomes disconnected (e.g. if the battery terminals are not strongly attached and you drive over a bump), where the load on the alternator/regulator circuit disappears. This produces a surge voltage over 100V (I've seen numbers as high as 160V mentioned) for several hundred milliseconds. The varistor is supposed to absorb a lot of that energy but in the worst case it will fail; with luck, it will fail short circuit and blow a fuse upstream. (You could - and probably should - include a fuse to the right of the varistor in this circuit.)
That varistor specified has a clamping voltage of 39V but they're no longer available. Now, I recommend the Littelfuse V18AUMLA2220 which is an SMT part. It has similar specifications.
VMM is the automotive 12V rail with no further protection. It's used as the positive supply for the LED pod circuit just below it. These can't be powered from VDD because they draw significant current and this would cause voltage drop across RD. This means the LED pods may have to withstand up to 40V in worst case conditions.
There are other way to protect circuitry against surges on the automotive supply - a high-voltage switch that simply disconects the circuit on overvoltage may be suitable.
VDD is the supply voltage for the circuitry, after the second stage of protection, which consists of a series resistor, RD, 10Ω, and a 15V, 3W zener diode to 0V, with another smoothing capacitor.
Also - is the RD10R a 10Kohm resistor?
10Ω and should be rated for 5W. I should have mentioned that on the diagram!
And - Kris states that each IC must have a decoupling capacitor (0.1uF ceramic) connected to the VDD and VSS pins. Does this include a 555 timer if I were using one?
Yes, definitely -
especially for a 555. The 555 generates nasty current pulses at its supply pins when the output changes state.
