Mook Johnson
Have you considered push pull. No fancy high side gate drivers to deal
with. Full(two quadrant)flux swing on the core.
Doesn't current mode pretty much get rid of those problems?
Best regards,
Spehro Pefhany
"it's the network..." "The Journey is the reward"
[email protected] Info for manufacturers:http://www.trexon.com
Embedded software/hardware/analog Info for designers: http://www.speff.com- Hide quoted text -
- Show quoted text -
Spehro said:Hmm.. nasty, nasty peak currents, >100A.
Spehro said:To make a battery charger circuit that will run from a 12VDC
regulated supply and produce (up to) 60V at 3-4A, what SMPS topology
would be recommended? I've gotten the suggestion of a flyback, but
240W seems a bit on the high side for that.
Input current should max out around 25A (80% efficiency) so I suppose
MOSFETs will be the way to go. Forward converter?
Anyone feel like putting together a real design? We need to make a
dozen or two of them, so it just has to work right the first time,
not necessarily be particularly cheap.
They're NiMH, I want control over the algorithm- thermistor as well
as voltage depression (and discharge) and prefereably the ability to
change battery technology with approximately the same voltage
(currently 33 cells and 16 cells per pack). I also have to deal with
possible charger-charger interaction. Lead acid is definitely not in
the cards, but one of the Li technologies might be, if it can be
proven safe.
Approximately 20 to 60V at 0.1 (?) to 4A, programmable by a micro.
Since it's charging batteries, current control is the ultimate goal.
A trickle charge capability is desirable.
No, within reason (the chargers can't interact to the point where
performance is affected). There is some commoning of one side of the
output lines, so a synchronized setup would be preferable so that
current and temperature could be measured without interaction. That
may be just a detail-- if it's designed in from the start.
The absolute simplest power control scheme would be hysteretic current
control of the the boost topology, which can be paralleled in constant
current mode. This brings up that 20-60V output at 0.1-4A output
current. You need to translate this to constant current mode
programmable from IL->IU with what compliance, and float charge constant
voltage programmable from VL->VU over what current range.
Yes...
Usually a
table or graph required here.
That is the easy part. The hard part is
tying in all the charging algorithms and fault protection as a function
of battery chemistry. TI has that BQXXXX series of multi-chemistry
battery charging control IC's. You're going to need something like that
as either the finished IC or embedded/emulated in a PIC controller or
something.
The finished circuit will be simple enough, but the design
effort will be non-trivial.
Hi Spehro -
Do you received my private email?
Regards -
Henry
I'm really not worried about the algorithm.. it's less than a page of
C to implement the most complex NiMH algorithm used by chip makers,
including recovery from over-discharge, which the present micro-based
"commercial" units don't properly implement. The battery manufacturers
also publish (somewhat incomplete) information which is useful for
charge termination parameters for a given cell.
Iout = f(Vcell(t), t, T(t), ncells)
Agreed. But not a crazy amount of work.
Best regards,
Spehro Pefhany
If you can't get OTS then the best topology is the Boost, similar to aSpehro Pefhany said:To make a battery charger circuit that will run from a 12VDC regulated
supply and produce (up to) 60V at 3-4A, what SMPS topology would be
recommended? I've gotten the suggestion of a flyback, but 240W seems
dozen or two of them, so it just has to work right the first time, not
Best regards,
Spehro Pefhany
Go with the fashion, "digital power". Compute PWM of the boost
converter drive(s) based on measurements.
John
flyback but no custom transformer, the push pull and forward converters have
discontinuous input current and custom transformers. Any resonate topology
is not viable at low voltages. Your 25A input current is better handled with
two interleaved boost channels 180D out of phase. The UCC2820 will handle
all the drive functions at about 200KHz PWM.
http://focus.ti.com/lit/ds/symlink/ucc28220.pdf
If the input inductors are still two big, go to three or four channels at
120D each, the inductors would be OTS. This would cut your output storage
caps in half. It is always a good idea to use more silicon and spread the
heat. At 90% efficiency, that is 27 watts of power loss. This can be
increased to about 93% with synchronous rectifiers for the high side diodes.
YMMV
Harry
Spehro said:Yes, Henry, thanks. I'm going to look at your German patent over
breakfast. ;-)
German Patent office-- Fusball & Technik?
http://www.patent-und-markenamt.de/infos/fussball/wm2006/index.html
http://www.speff.comSpehro Pefhany said:To make a battery charger circuit that will run from a 12VDC regulated
Best regards,
Spehro Pefhany
john said:I did a 12V car battery, to 50V at 3Amps boost
Clifford Heath said:I need to do something casual like that sometime soon, to drive a
servo'd rcar rooftop antenna rotator... so if you could casually
answer a couple of questions I'd appreciate it.
Did you do a boost, flyback or some other topology?
On what is tri-rated wire actually rated?
Clifford Heath.
john said:'Tis a standard 'Boost' ie, Supply > Inductor > Fet > deck.
Best I remember it, is that "Tri-rated" is multistand wire with insulation
[Sounds interesting project!]
