Wanted: 110 volt AC Electric motor
No,I. Really just trying to figure a similar power demand out... no solution thus far...only have 110v power available but need at minimum 3 hp motor running
You will be hard pressed to find a 120v 5hp 1ph motor.
Your best bet is a 240v 3ph version with a VFD.
240v 1ph supply.
I am not sure you will find a 5HP for 120vac.
Even if you could find one the 120v current of 30a-40a would still be required before conversion.
Seeing you are in N.A., can you not supply the 240v 1ph for a suitable one?
