Daniel Pitts
I'm trying to design a remote controlled volume controller, and the chip
I've chosen to control the volume needs ±5v for the analog side of the
circuit, and +5v for the digital.
I have several options for input voltage, mostly based on old AC
adapters I have laying around. In particular I have a "selectable"
adapter which can select up to 12v, but I may have others with higher
voltages (I haven't looked through them recently).
One idea I had was to chain 7805s together:
+12v connected to VinA & VinB
GndIn connected to GndA
VoutA connected to GndB
If I understand correctly, I could then use VoutA as my reference point,
making GndA -5v and VoutB +5v.
If I do this, am I going to let the magic smoke out? Is there an easier
way to do what I'm trying to do? It seems like most ±5v chips I've found
require a bit more complicated external components, and are far more
expensive.
Thanks,
Daniel.
expensive.
Thanks,
Daniel.
