On Tue, 23 Apr 2013 17:54:37 -0500, John Fields
On Tue, 23 Apr 2013 12:27:24 -0500, John Fields
On Tue, 23 Apr 2013 09:24:04 -0700, John Larkin
On Mon, 22 Apr 2013 22:34:47 -0700, John Larkin
Sometimes I post schematics with values, sometimes Spice sims, sometimes sheets
from actual products.
But mostly you post braggadocio.
I mostly post circuits. If you perceive my circuits as "braggadocio" you must
think that they are pretty good. Thanks for the compliment.
No compliment intended, and you don't mostly post circuits, you mostly
post self-aggrandizing rhetoric exalting yourself at the expense of
others.
Your LED thing is OK, but it does have a dead zone.
You shouldn't me making commentary if you don't read the spec's.
Panfilero wrote: "I was making a circuit that when you power it up
with 5V a 5V LED indicator turns on and if you power it up with 12V
the 5V LED goes off and the 12V indicator goes on."
You could eliminate that and
reduce the parts count by taking the output of one comparator, inverting it, and
driving the second LED.
That's just klunky.
Here's a rather less klunky way of doing it:
+5/12>--+---------+-------+--[5k1]--+
[430R] [10k] | [LED] 12V IN
| 3.3V +------|-\ |
+---------|------|+/TLV7211 |
[1N5226B] [5k1] | [LED] 5V IN
GND>----+---------+-------+--[1k5]--+
Just for grins, using LTC library parts:
Version 4
SHEET 1 880 680
WIRE 128 -16 -192 -16
Full .ASC file at...
Message-ID: <
https://dl.dropboxusercontent.com/u/53724080/Optos/LED_Diff_Pair.JPG>
SYMATTR InstName U1
TEXT -160 384 Left 2 !.tran 5 uic
Looks like the LTspice LED model is for a white LED. That's why I
just reworked my PSpice libraries so that "RED" definitely calls up a
RED model.
