I thought it would be neat to start a discussion asking what everyones very first self designed circuit was that worked? This is a circuit that you thought through and used the limited knowledge, limited budget, and tools you had at the time to make it work.
Mine was in 1984 I wanted to make a 10 position rotary switch change a RED 7-segment LED to display 0 through 9. Being just 9 years old this circuit was very crude and later on I found out about the 4511 7-segment Decoder/Display Driver IC which was far less soldering to make it work just having to feed this 4511 a binary input to get the desired output.
My circuit had 47 diodes with the following diode count for each digit displayed.
0 = 6 diodes
1 = 2 diodes
2 = 5 diodes
3 = 5 diodes
4 = 4 diodes
5 = 5 diodes
6 = 5 diodes
7 = 3 diodes
8 = 7 diodes
9 = 5 diodes
At the time I thought it was really cool being just 9 years old and coming up with it on my own using the diodes as 1 way valves for the electrons to the LED segments, and while it worked, there was also some leakage that caused segments that shouldnt be lit to be very dimly lit at times, but you could clearly switch the rotary switch in all 10 positions and watch as it went from 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
The application at the time... there really wasnt one, I just wanted to make this circuit and bring it into school and show friends and amaze the teachers of what I did on my own.
The many diodes which may have been 1N4148 or 1N914 's I bought at Radio Shack in packages of 25 i think it was. Back then they use to have a Battery Card in which you could get 1 free battery per month if you brought your card in and they would give you any AAA, AA, C, D, or 9V for free but the other batteries like 6 volt lantern batteries and N etc were excluded. ( I generally went for the D or 9 volt batteries, since I knew that the D batteries lasted longer with higher mA rating, and the 9 volt batteries I could use for circuits 9V or less that were circuits without a heavy battery load.) So I use to get my free battery every month in the 1980s while this program lasted to power my experiments without having to steal so many batteries from my younger brothers toys for portable projects.
0 = 6 diodes
1 = 2 diodes
2 = 5 diodes
3 = 5 diodes
4 = 4 diodes
5 = 5 diodes
6 = 5 diodes
7 = 3 diodes
8 = 7 diodes
9 = 5 diodes
