XM radio in Tortola?
L
Larry
I'm further inside the footprint up here in Maine than Tortola would
be down there and it does not work that well.
I had the antenna mounted on the headlight shell of my motorcycle and
it would drop in and out as I rode. That was an area with a clear sky
view and the headlight shell give it some ground plane.
Tall tress 50-100 yards from the road could block it at times and I
suspect it was because the look angle was at a lower azumith and the
trees were in the way. On narrow roads with trees right along the
roads, it was gone for sure until I got back out into the open.
I gave up on using it on the bike for now. Maybe if I ever go cross
country and get onto more wide open interstates and stuff it will get
another chance.
Jack
At that high latitude, the bird's angle is quite close to the horizon, I
suspect. Overhead trees aren't a problem. The truck in front of you
would be. Here in SC, our sync orbit birds are at 45 degrees. That's
not as low as yours, but it's still an issue. In Tortola, at least, the
bird will be very high in the sky. I don't think they can point the
antenna so narrow without using lots of fuel to keep it pointed. We'll
see how it works. It's going, anyways.
http://directv.com/DTVAPP/customer/dishPointer.jsp
Although you can't point the standard XM antenna, this pointer
information from DirecTV can help you understand how low in the sky the
bird is in Maine or anywhere. DTV's birds are at different longitudes,
but must be at the same sync orbit to stay in place as XM.
Playing with the website, it looks like Maine's elevation to the birds
would be about 31 degrees.....very low towards the horizon and easy to
block, even if overhead is perfectly clear. Just driving by a 2 story
building in Maine would block the signal if you were driving East or West
or anything but SSW/NNE. There's another problem, YOU! If the antenna
were on the front of the bike and you were driving northerly, between the
antenna and the bird would be YOU...and you are quite a microwave
absorber. Your body would block the signal on any northerly trip, within
150 degrees.
Larry
