WWV receiver
Joerg
Hello Peter,
Converting a 60 KHz receiver to 10 MHz is likely impossible -
construction techniques and tuned circuits will be quite different -
you can almost use audio techniques and iron-core coils at 60 KHz, but
are well into RF territory at 10 MHz, and will likely have to use
air-core coils in the tuned circuits.
Not just that. The transmitted code is also different.
Regards, Joerg
X
xpyttl
Huh? Yes, he is well into RF and construction techniques will be different.
But while there are advantages to air-coil cores, their use in recievers
went out with hollow state detectors. Even in transmitters they tend to be
only used in the KW neighborhood anymore. I can't imagine that even in the
wilds of BC people are winding air coils and building on heavy steel
chassis.
X
xpyttl
He wants to listen, and at least at 10 MHz there's something to listen TO.
The 60Khz signal is pretty strange.
Michael A. Terrell
No, its not. It was never intended to be listened to. It has a 1 BPS
data rate encoded time signal that has always been used to carry time
code.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Joel Kolstad
I think that Coilcraft, API-Delavan, Pulse, etc. would be surprised to hear
them. Although I'd grant you that you don't typically find many air coils in
mass-market consumer electronics anymore, they're still used all over the
place in industrial and military design... where I work we buy tens of
thousands of the things every year for radio receivers!
Plenty of articles appearing in QEX and on-line also use air-core coils, since
it's a pretty fast and you can, of course, get whatever value you want with no
"minimum purchase" quantities.
---Joel Kolstad
Joerg
Tobin wrote "... easier to decode". So I guess he is after decoding and
not so much after listening.
Regards, Joerg
Joerg
Hello Joel,
To imitate an old Volkswagen ad: Air doesn't saturate. Well, I guess it
does at some point but that's way past where ferrites and iron powders
do. Today many inductors in receivers are designed around iron powder
cores but when it comes to heavy-duty stuff air cores are the ticket.
Same for really high-Q tuning circuits.
Regards, Joerg
