I was recently given an SA-290 that works pretty well honestly. The guy told me it had a "volume problem" and hadn't used it in several years. Hooked it up and it worked for a couple days, sound thru the radio and through the RCA inputs. Then the radio receiver portion cuts out and the signal meter and frequency display start flashing and it seems to lock up when flashing, it will show the frequency (i.e. 94.7) but it won't respond to memory inputs. Sometimes I can turn it off and back on and the tuner will work for a bit, kinda depends. Funny thing is the RCA inputs work fine, it still puts out great sound from the other parts I have hooked up, only the tuner is screwy. Any advice/ suggestions? I'm not extremely good at figuring out electronics, fair at it.
