Skybuck Flying said:
For addition and subtraction probably.
For multiple and division some performance could be reduced for 32 bits
but would still be faster than simulating it.
Not likely. On common 64-bit machines, all operations take the same amount
of time regardless of whether they're 32- or 64-bit, so there's no potential
speedup. So, you're only talking about potential benefits of not using
emulation on older 32-bit machines. The performance of detecting the 32-bit
case and then branching to either the 32- or 64-bit code paths (or, in the
16/32-bit equivalent, setting a bit in the segment descriptor) will usually
outweigh the savings you'll get from not needing to emulate 64-bit
operations. Even if it's not a certain victory, the programmer cost of the
code complexity will likely decide things in such a case -- especially since
it only benefits people with outdated machines.
Whatever the case maybe.
The point is the detection is the overhead if cpu can do the detection
that overhead might disappear !
Adding that detection logic into the CPU will just change where the overhead
is paid for; that cost has to be paid _somewhere_.
You seem to think that counting instructions is how to measure speed. That
hasn't been true on x86 since the days of the 486, or possibly even earlier.
Memory latency, cache (both instruction and data) hit rates, BPU and BHT
misses, utilization of varying types of functional units, parallelism, OOE,
and various other things mean the _only_ way to determine what's fastest is
to actually write the code and test it -- and the answers may be different
depending on the chips being used.
You are postulating chips that do not exist (this mythical BitMode) and that
the makers have shown no interest in making. You also ignore the cost of
figuring out what to set the BitMode too, as if that were free. You further
ignore how width-independent instructions are supposed to know how much data
to load/store, or how the compiler is supposed to efficiently reserve space
for such when the data types are not known at compile time.
