Skybuck Flying
Hello,
This morning I had an idea how to write Scalable Software in general.
Unfortunately with Delphi 2007 it can't be done because it does not support
operating overloading for classes, or record inheritance (records do have
operator overloading)
The idea is to write a generic integer class with derived integer classess
for 8 bit, 16 bit, 32 bit, 64 bit and 64 bit emulated.
Then at runtime the computer program can determine which derived integer
class is needed to perform the necessary calculations.
The necessary integer class is instantiated and assigned to a generic
integer class variable/reference and the generic references/variables are
used to write the actual code that performs the calculations.
Below is a demonstration program, it's not yet completely compiling, but
it's getting close.
// TestWritingScalableSoftware.cpp : Defines the entry point for the console
application.
#include "stdafx.h"
class TSkybuckGenericInteger
class TSkybuckInt32 : public TSkybuckGenericInteger
private:
int mInteger;
public:
// constructor with initializer parameter
TSkybuckInt32( int ParaValue );
// add operator overloader
TSkybuckInt32& operator+( const TSkybuckInt32& ParaSkybuckInt32 );
void Display();
class TSkybuckInt64 : TSkybuckGenericInteger
private:
long long mInteger;
public:
TSkybuckInt64( long long ParaValue );
TSkybuckInt64& operator+( const TSkybuckInt64& ParaSkybuckInt64 );
void Display();
// TSkybuckInt32
// constructor
TSkybuckInt32::TSkybuckInt32( int ParaValue )
mInteger = ParaValue;
TSkybuckInt32& TSkybuckInt32:perator+ ( const TSkybuckInt32&
ParaSkybuckInt32 )
mInteger = mInteger + ParaSkybuckInt32.mInteger;
return *this;
void TSkybuckInt32:isplay()
printf( "%d \n", mInteger );
// TSkybuckInt64
// constructor
TSkybuckInt64::TSkybuckInt64( long long ParaValue )
TSkybuckInt64& TSkybuckInt64:perator+ ( const TSkybuckInt64&
ParaSkybuckInt64 )
mInteger = mInteger + ParaSkybuckInt64.mInteger;
return *this;
void TSkybuckInt64:isplay()
printf( "%lu \n", mInteger );
int _tmain(int argc, _TCHAR* argv[])
long long FileSize;
long long MaxFileSize32bit;
// must write code like this to use constructor ? can't just declare
a,b,c ?
TSkybuckInt32 A32 = TSkybuckInt32( 30 );
TSkybuckInt32 B32 = TSkybuckInt32( 70 );
TSkybuckInt32 C32 = TSkybuckInt32( 0 );
C32 = A32 + B32;
C32.Display();
TSkybuckInt64 A64 = TSkybuckInt64( 30 );
TSkybuckInt64 B64 = TSkybuckInt64( 70 );
TSkybuckInt64 C64 = TSkybuckInt64( 0 );
C64 = A64 + B64;
C64.Display();
FileSize = 1024; // kilobyte
FileSize = FileSize * 1024; // megabyte
FileSize = FileSize * 1024; // gigabyte
FileSize = FileSize * 1024; // terrabyte
MaxFileSize32bit = 1024; // kilobyte
MaxFileSize32bit = MaxFileSize32bit * 1024; // megabyte
MaxFileSize32bit = MaxFileSize32bit * 1024; // gigabyte
MaxFileSize32bit = MaxFileSize32bit * 4; // 4 gigabyte
if (FileSize < MaxFileSize32bit)
TSkybuckGenericInteger AGeneric = TSkybuckInt32( 30 );
TSkybuckGenericInteger BGeneric = TSkybuckInt32( 70 );
TSkybuckGenericInteger CGeneric = TSkybuckInt32( 0 );
} else
TSkybuckGenericInteger AGeneric = TSkybuckInt64( 30 );
TSkybuckGenericInteger BGeneric = TSkybuckInt64( 70 );
TSkybuckGenericInteger CGeneric = TSkybuckInt64( 0 );
CGeneric = AGeneric + BGeneric;
CGeneric.Display();
while (1)
return 0;
Probably minor compile issue's remain:
Error 1 error C2243: 'type cast' : conversion from 'TSkybuckInt64 *__w64 '
to 'const TSkybuckGenericInteger &' exists, but is inaccessible
y:\cpp\tests\test writing scalable software generic math\version
0.01\testwritingscalablesoftware\testwritingscalablesoftware\testwritingscalablesoftware.cpp
152
Error 2 error C2243: 'type cast' : conversion from 'TSkybuckInt64 *__w64 '
153
Error 3 error C2243: 'type cast' : conversion from 'TSkybuckInt64 *__w64 '
154
Error 4 error C2065: 'CGeneric' : undeclared identifier y:\cpp\tests\test
157
Error 5 error C2065: 'AGeneric' : undeclared identifier y:\cpp\tests\test
157
Error 6 error C2065: 'BGeneric' : undeclared identifier y:\cpp\tests\test
157
How to solve the remaining issue's ?
Bye,
Skybuck.
it's getting close.
application.
#include "stdafx.h"
private:
int mInteger;
public:
void Display();
private:
long long mInteger;
public:
void Display();
// TSkybuckInt32
// constructor
ParaSkybuckInt32 )
return *this;
// TSkybuckInt64
// constructor
ParaSkybuckInt64 )
return *this;
long long FileSize;
a,b,c ?
C32 = A32 + B32;
C32.Display();
C64 = A64 + B64;
C64.Display();
} else
CGeneric.Display();
while (1)
return 0;
152
153
154
157
157
157
Bye,
Skybuck.
