It's a 10 coil polyphonic (Wal style) pickup, with each coils having 2 tags for outputs and one larger tag to ground out the internal shielding of the pickup, Is that the kind of information you need?
This is exactly the information I need.
acguitars said:
The MC Series Multi-Coil Pickups have two coils per string. In a 4 string pickup there are 8 poles, 2 per string, where each pair of coils is wired in series as a humbucker. In other words each string has its own dual coil humbucking pickup.
The individual outputs from each string feed an ACG IB1 interface board, which mixes them electronically. The multiple coils and electronic mixing reduces the interaction between the strings coil signals, since there is no cross-feeding between string signals as with traditional pickups, where the same magnet systems and coils are used for all strings.
This leads to improved dynamics and far greater clarity over the entire range of the bass.
but the link you provided have me slightly better details
Keep in mind what you are doing, and what is in the description are two completely different approaches.
The board described will mix the signals together and prevent the coils from interfering with each other. This is only to a certain extent though because the pickup contains pairs of coils connected in series, and no board will compensate for that. What the described board does is mix the signal from each
pair preventing the pairs from interfering with each other. This sounds like an 'active' device and would need power but would give you a signal free of interference from the other coils.
You are after a 'passive' solution because you do not want a power source to be involved.
You can connect the coil pairs in series or parallel, this is entirely up to you. You can make it selectable, but will need a switch that can toggle at least 5 poles which may be pricey. Otherwise you wire it and forget about it.
Here are your options:
Series connection. This would result in all of your coils being connected in series. (Top of one terminal would be connected to the bottom of the next. Repeat to connect the top of each pair of coils to the bottom of the one next to it. The two left over at either end will be sent to the amp)
Parallel connection. This would result in 5 pairs of series coils all connected in parallel. (Top terminal would be connected to the top terminal for all other coils. Bottom terminal would be connected to the bottom terminal for all other coils. Top and Bottom would be sent to the amp)
Optional slightly experimental method.
This is the same as the Parallel method, but a small value resistor is added for each pair of coils... This method will reduce, but not eliminate the drawback of parallel wiring at the expense of a weaker signal making your guitar quieter. This is only suggested if you were willing or able to experiment with the setup.
