Hi ES,
I am making a lamp, it is going to have 3 bulbs connected to their own dimmer switch. I bought a 2 way 400W 10 Amp 3 gang dimmer switch, each bulb will be 40w i know 60w is the minimum load for 400w switch but im assuming this will be ok.
My question is how do you wire it? (internally and to the mains) I take it L2 is not in use as it is only a 1 way switch. Will it be like like my diagram
Have i worked out the amperage right ? From the mains to i connect a 6:1 transformer? im a bit unsure what to do after this, as if 2 of the lights are off then wont the third receive 3 times the power? I know its probably a lot to explain, I am a novice when it comes circuitry, i did a degree in physics though so i quick to learn. Can you guys guide me with your own knowledge if you have the time or some relevant material.
