Wiring a relay
im trying to relay a speaker output? I have a circuit that delays for 5 sec.... but I need some help...
Could I use pins 3 and 10 for each speaker input?
Then use pins 5 and 8 for output?
What are pins 4 and 9 connected to?
thank you
Common pins (4 & 9) , Normally Closed pair (3 & 10) to device 1, and Normally Open pair (5 & 8) to device 2. one of the common pin should be your input (Audio), Connect normally closed to a speaker.
When delay circuit is active, energize the relay, so your audio input will go to the pin 5 and 8. which will do nothing and when delay is over, Deenergize the relay. Hope this helps.
Unless if your delay circuit works the other way. meaning if ir is off for the time period of 5 sec and on the rest of the time. Then you will have to swap pins 3 with 5 and 10 with 8.
