I just HAD to Google it. Trust Steve, the pics are pretty disturbing.
This is the equipment he used to create the effect, called a Mandoline. I think perhaps these should all be dismantled and destroyed.
Info from
https://en.wikipedia.org/wiki/Mandoline
A mandoline consists of two parallel working surfaces, one of which can be adjusted in height. A food item is slid along the adjustable surface until it reaches a blade mounted on the fixed surface, slicing it and letting it fall.
Other blades perpendicular to the main blade are often mounted so that the slice is cut into strips. The mandoline juliennes in several widths and thicknesses. It also makes slices, waffle cuts crinkle cuts, and dice with firm vegetables and fruits.
With a mandoline, slices are uniform in thickness, which is important with foods that are deep-fried or baked (e.g. potato chips), as well as for presentation. Slices can be very thin, and be made very quickly, with significantly less skill and effort than would be required if cutting with a knife or other blade.
A mandoline is used by running a piece of food (with some protection for fingers) along an adjustable inclined plane into one or more blades. On some models vertical blades cut to produce julienne, or a wavy blade is used that produces crinkle cuts. In these models a quarter turn to the food between passes produces dice and waffle cuts.
