newhaven serial display
Hello all, I am working on a project in which I plan to send data to an LCD display using an arduino. However, I was looking at the input pin numbers on the datasheet, and while they tell you which numbers correspond to which functions, they don't have the numbered pins labeled on the diagram itself! How can I figure out which pin is which? The datasheet is here: http://www.newhavendisplay.com/specs/NHD-0220D3Z-NSW-BBW.pdf
Thanks!!!!
Yes they do.
Look on the diagram on page 3.
Pins 1, 2, 15 and 16 are clearly labelled.
