Platforms
Content
With your post #1 circuit, if you increase the time constant R7C2 to at least ten times the period of the triangular wave you should see an approximation of a sine-wave at the output, albeit of much lower amplitude than the triangular wave. The greater the time constant the better the approximation will be, but the lower the amplitude.What should I do so the third one gives me a sine ?
Sorry I didn' see it. My bad. It is definitely wrong.It's there
I will agree with that. For some reason, it took me years to understand the concept of pointers in C programming. I still "feel uncomfortable" using indirect addressing even in assembler programming. Apparently I am not very good at abstracting. So, to answer the OP's original question, "Why don't I get a Sine wave?" I think I will defer to @Alec_t's explanation in his post #22.I don't think relative or indexed addressing is "easy as pie" for someone who has never written a line of code.
Quite easy, all you need is a good teacher...don't think relative or indexed addressing is "easy as pie"...
FINALLY!! I take back half the things I've said about you.I copied then corrected the original circuit:
Thank You.FINALLY!! I take back half the things I've said about you.
ak
And yet another testimonial to "simulating" with real components. Bob Pease still lives in the analog community!... I did not sim it because I cannot remember how to sim a squarewave signal.
So am II am sure the OP has long fled this scene.
