L
lurch
Doesn't that sort of thing happen when intermittent shorting or arcing
trips a breaker somewhere and the breaker makes automatic re-tries ?
Derek.
I would describe such events as a bit more than a flickering.
Derek.
*plonk*? said:-----------------------------
Please check the definitions of demand and capacity - as the above is
nonsense.
Ideally the capacity should exceed the demand by some optimal margin but
as adding and dropping on line capacity is in blocks corresponding to the
capacity or rating of individual generators, and demand is up to the
customers (predictable but not controllable) the capacity will normally
exceed the demand by a fairly large margin at times- there is no
"stability" problem. As for waste by having extra on-line generation-
economic dispatch optimization is a common procedure.
If demand exceeds capacity, then problems can occur- not necessarily
stability problems.
As for the wind turbine reserve, you are being a bit over optimistic.
You are assuming 30% availability of wind capacity. In practice, from
recent data it appears that 10-15% is a better figure and this is a
statistic based on an annual average, which means nothing if wind fails.
In other words. reserve capacity must be available for the worst case
situation- 100% failure of any generation source, concentrated as in a
500MVA fossil plant or distributed as in 500-1MVA wind units in a region
where wind diversity is small.
Tzortzakakis Dimitrios said:*plonk*
Androcles said:What would you expect from someone original enough
to give his name and address as noone@nospam?
Androcles said:British citizens nowadays carry drugs into China
to get themselves executed;
they have good ol' Gaelic, Cymru or Anglo-Saxon
names like "Akmal Shaikh".
I'm surprised Gordon Brown isn't wearing a turban to get himself
re-elected.
Androcles said:I know this is going to be hard for you to understand, but Britain has
citizens that are not subjects.
Androcles said:Oh look. You already have.
Tzortzakakis said:*plonk*
You are both fucking retarded.What would you expect from someone original enough
Shouldn't you be busy cutting holes in your bedsheet now?
BTW, only fuckwits piss about with follow-ups.
Sigh... too bad.
Don's quite right on the matter. 'Capacity' is not the current
production, but the current maximum possible by on-line equipment. So
it is always kept greater than demand. 'Production' is matched to
demand by a variety of techniques. Most notably, manual operation of
base load settings and governors of regulating units.
'Spinning reserve' is kept on line to respond to sudden losses in
capacity by a unit trip. Most system operators are required to maintain
enough spinning reserve available for the tripping/loss of the largest
generating unit. So if the system has a very large unit on line (say,
1000 MW), they must have at least that much spinning reserve. So you
could say the system has a 'capacity' that is kept 1000 MW higher than
demand.
daestrom
This is an attack ad hominem. I should check the definitions? Nobody forcesÏ "Steve Firth said:Excellent eco-weeny response there. Stick your fingers in your ears and
refuse to listen to hard fact. The plonk went to:
nonsense.
If you read my signature, at the bottom is my real email address. So far,Ï "Androcles said:What would you expect from someone original enough
Generating capacity, maybe?? "daestrom said:Sigh... too bad.
As long as base units are synchronised, their most efficient use is toSo it is always kept greater than demand. 'Production' is matched to
demand by a variety of techniques. Most notably, manual operation of base
Here, in Crete, we have fast units (gas turbines) that synchronise in 11-12'Spinning reserve' is kept on line to respond to sudden losses in capacity
by a unit trip. Most system operators are required to maintain enough
spinning reserve available for the tripping/loss of the largest generating
unit. So if the system has a very large unit on line (say, 1000 MW), they
must have at least that much spinning reserve. So you could say the
system has a 'capacity' that is kept 1000 MW higher than demand.
No it's not. You don't appear to understand the term "ad hominem".
Yes. If you're going to pontificate about something which can be
measured objectively then you would do well to check your sources before
you start to talk about the subject. Otherwise you could end up looking
like someone who doesn't know what he's talking about. You were being
given good advice which you respond to like a child throwing a rattle
out of a pram.
No one posted an insult, plain or flowery. No one can force you to read
anything. You chose to read the post, you chose to flounce.
Tzortzakakis said:Generating capacity, maybe?
I think it's installed power. I might be wrong, of course (since many people
seem to forget) I am greek and have gotten my degree in Greece. My English
is acceptable, but only God is always right.OTOH, we mere mortals...
operate 24/7 at full load. When they need to reduce output at night, they
might eg reduce coal supply
mins. Even the (small) steam units, 3-4 hours and the 2-stroke diesels 1/2
an hour. I think hydro can synchronise in quite fast, too.
----Tzortzakakis Dimitrios said:This is an attack ad hominem. I should check the definitions? Nobody
forces me to read plain insults.
major in electrical engineering
mechanized infantry reservist
hordad AT otenet DOT gr
------------------Tzortzakakis Dimitrios said:Generating capacity, maybe?
people seem to forget) I am greek and have gotten my degree in Greece. My
English is acceptable, but only God is always right.OTOH, we mere
mortals...
-------------Here, in Crete, we have fast units (gas turbines) that synchronise in
11-12 mins. Even the (small) steam units, 3-4 hours and the 2-stroke
diesels 1/2 an hour. I think hydro can synchronise in quite fast, too.
