I
ITSME.ULTIMATE
Often time, they're rated less than ten hours. Why do they have such a
short life?
short life?
I think they also compensate for overvolting. Two cells = 3.0 volts atIan said:Compromise between efficiency and long life.
You can get flashlight size bulbs that last tens of thousands of hours,
but they are well under half the brightness.
Just for reference here are how the common battery types will work for
voltage:
Non-Flashlight batteries for reference:
-Lead Acid: 2 volts per cell (2.1 when charging) MUST STOP DISCHARGE at
1.75 volts / cell!
ITSME.ULTIMATE said:Often time, they're rated less than ten hours. Why do they have such a
short life?
1.75 volts / cell!
I think you're right on this one, thanks, I don't deal with batteriesDon said:More like supplying 2.1 volts per cell to a light to moderate load when
fully charged, and has a voltage of about 2.35-2.4 volts per cell during
charging when approaching full charge and about 2.3-2.4 volts per cell
with charge being maintained (such as in a running automobile).
- Don Klipstein ([email protected])
What Ian said. You may have noticed how much whiter the
flashlight bulb is compared to a mains fed lamp. The short
filament can take the heat better as well.
While I'm at it, When I buy a new 2 cell flashlights, I ususally
remove the battery draining .75 amp Krypton bulb and install a
PR-6 that draws 300 some ma. In most cases, I need better run
time than high brightness. The PR-6 may be more efficeint with
batteries anyway because the cell voltage drops faster with the
krypton bulb that it is runing in a lower effeciency state. I
don't use the more common PR-4 bulb because the rated bulb
voltage is lower and it burns out quickly.
I use a Xenon gas filled bulb rated at .5 a give the good mix of
runtime and brightness in C and D cell flashlights.
LED flashlights are the best. As the voltage drops, the light
output does not drop as fast since incandescence is not relied
upon to produce the light. My Luxeon white LED Dorcy that uses 3
AAA is my favorite flashlight. My 4 D cell Mag light with .5
Xenon bulb is the brightest, but to heavy to take everywhere.
Can I repost something I aksed here recently but go no replies to.
It seems quite closely related to the topic for this thread....
Is the "K2" designation on a flashlight bulb an indication of its
current consumption?
All I can find is this:
"Rayovac introduced the krypton flashlight lamp to
the mass market. We gave these new numbers, K-1, K-2,
K-3, K-4, and K-13. These lamps are now industry
standards, and are identified as KPR-102, KPR-113, etc."
<http://www.rayovac.com/flashlight/bulbs.htm >
Can someone tell me what K2 (and K3, K4, etc) actually refers to?
These refer to krypton-filled versions of the original
industry-standard
PR2, PR3, PR4, etc.
I do not know if current consumption of the krypton-filled
versions is
standardized, but I have seen current specifications indicating
more current than the PR types draw.
It appears to me that the PR ones draw mostly close to half an
amp (less
for the PR4, a lower current version of the PR2) and the krypton
versions draw about 1/4 amp more than the original versions do.
such a short life?
DISCHARGE at 1.75 volts / cell!
Nope, the highest I've seen for a flashlight bulb is 40 hours. That'sDavid said:10 hours?
That seems amazingly short. There isn't a missing zero is there?
Once or twice, charged promptly probably won't kill it.
(I have a battery in my car, that when I went to it in the
morning, it read 8mv, after charging, it started the car without
problems, and has for several months)
David Peters said:8mv ??
{{{ swoon! }}}
