Who sells a wall mounted 4 x AAA and 4 x AA Nimh battery charger?
Acme
Looking for a single charger that charges both AAA and AA and must be
wall mounted. I hate clutter. :)
Jaycar website doesnt seem to have them.
cheers.
Alan Rutlidge
Acme said:
Looking for a single charger that charges both AAA and AA and must be wall
cheers.
I purchased an Energizer unit from an Australia Post outlet quite some time
back. Rapidly charges high capacity AA and AAA cells (NiCd and NiMH in less
than 1 hour). Actual charging base is approx 12.5cm tall x 68cm wide and
2.5cm thick. Has a flat back so it can easily be mounted on any smooth
surface with double sided tape. AC wall plugpack is a switchmode type,
light weight about 9cm high x 5cm wide x 4cm thick when plugged into wall
outlet. Also has a 12V DC ciggy lighter cord supplied for use in the car.
Never models can be viewed here -
http://www.energizer.com.au/products/rechargeables/sizes.aspx
Try BigW, Coles, K-Mart and most chain hardware shops as potential retail
outlets.
Altronics sells similar units - see
http://www.altronics.com.au/index.asp?area=prod&grp=262 for a selection of
possibly suitable chargers.
Cheers,
Alan
matt2-amstereo
small piece of MDF and some zip ties?
otherwise, you could take the cover off, find there a screw can go thru
safely and do that.
Acme
outlets.
Cheers,
Alan
Excellent, thanks. Those power point mounted packs is what i was after.
Acme
safely and do that.
Thanks for trying. :)
