perhaps they did have a flaw in the routing/materials of
one wiring harness, but show me a comparable vehicle at the same price
point that handles better. To accuse BMW across the board of poor
engineering is laughable.
The bimmer handles well, and the power train is phenomenal.
However, the window regulators break on almost every BMW
older than about 5 years, while the blower motor final stage
resistor (FSR), aka the final stage unit (FSU) will fry itself
more than once on every single bimmer ever built in the late
90's and early 2000's.
The VANOS seals are made of a material that won't last the warranty
period; and the Bosch 5.7 ABS control module was placed far too close
to the engine for cost reasons, which fries almost every single one.
The DISA valve, which appears to be an amazing engineering feat,
is practically designed to loosen the pin, which, if the engine
ingests that steel pin, will wreak havoc on the valves as the
pistons pummel it to pieces (there is nothing between the DISA
valve and the intake manifold!).
The almost criminal design of the DISA is dwarfed by the clearly
deficient design of the cooling system, where almost every bimmer
older than a few years has had a catastrophic failure of, and very
many multiple failures. Thousands of bimmers every year are destroyed
by owners not realizing that a single overheating episode causes
cracks in cylinder 3 (e.g., in the M54 engine) that essentially
turn the otherwise fantastic power plant into so much rubbish.
And, there wasn't an E39 ever built (5-series, 1997 to 2003) which
did NOT have the cluster and MID pixels turn to unreadable junk within
a few years of manufacture (due to the infamous "pink tape").
Likewise, not a single E39 is immune to the horrid choice of PBT
plastic for the headlight adjusters, turning $1000 fiber optic
Halogen H7 and Xenon headlights into veritable candles within a
few years of the heat baking the plastic.
Likely not one E39 hasn't had its power steering hose leak under the
fluid reservoir, and not a single E46, E39, or E38 (3,5,6 series)
bimmer hasn't had the CCV valve fail on them (i.e., a PCV valve
which costs hundreds of dollars to replace, frequently).
For the V8, they all have valley pan gaskets leaking, and all the
bimmers I'm talking about have had their thrust arm bushings tear.
Probably not a single bimmer of the categories above hasn't had the
vapor barrier leaking (due to an extremely poor choice of design
coupled with lousy sealant); and half the bimmers have cables slip
out of the otherwise fancy seat, causing the infamous "seat twist".
I could go on (and on), (e.g., more than half will have the windshield
washer pumps leak, and a huge percentage will lose their jack pads,
while a healthy percentage will melt their center brake lamp housing,
and even the roundels will chip away at the car wash until nothing
but silver is left).
The funny thing is that BMW DOES know how to design a powerplant.
It appears that the Germans in Bavaria simply 'care' about some
things (just count the ashtrays, for example, and then compare
them to the unanimously ridiculous cupholders of the E39 era)
while they don't care about others.
Clearly BMW cares about handling and efficiency of the power train;
yet, just as clearly, overall product quality is NOT even on their
radar screens.
