what connector size
RB
Got several unmarked coax lines of different OD sizes.
I need to use some twist on bnc end connectors, as my application requires
occasional need to remove the connectors to pull the cables though a small
hole, then later reinstall the bnc ends.
The bnc twist on connectors come in several sizes.
Is there a chart or table that will tell me what coax type I likely have by
the OD measurement?
Do I need to trim a short length off the coax cable end each time I reuse
the bnc twist on fittings?
L
Larry Oravetz
Not that simple.. Twist ones need the correct center conductor wire
diameter. RG 6 and RG59 cables have different sizes eventhough the jacket OD
is the same.
