Weird LED circuit problem
Here's the problem- I have made this circuit-
But as soon as I connect the supply voltage, the LED blinks as it shoud for about 1/2 a second and then stops working altogether. Could this be because the connection from the supply voltage is not very good? I had to replace the battery clip I was using because the wirse on it were too thin and weren't making a proper connection.
You might have burnt out the LED, I tested the circuit on Yenka and it burnt the LED out. BobK is right you probably need a 390 Ohm resistor.
1) what value is your resistor?
2) what do you mean "altogether"? (until you cycle power, or until you replace it with a new one?)
1)The resistor connected to the LED is 470 ohms.
2) The LED blinks and then fades until it is no longer lit. The LED works ok I have tested on it's own, separately to this circuit.
measure the voltage across the power supply pins (1 and 8) and tell us what is happening.
