CJT
Sounds to me like you've got a solution in search of a problem.Pooh said:I think that's the point.
You could lose *any* given sample. The simplest method of dealing with that is to continually
broadcast the data twice. If the previous error rate was 1 in 10^-6 then that method ( assuming
random errors ) should reduce it to1 in 10^-12. Not *perfect* but pretty damn good !
Sending the data twice also removes the need for negotiation over missed samples between transmitter
and receiver. It sounds like a done deal to me.
That also explains the need for a much higher data rate than 1.4Mbps.
Graham
