Arny said:
In this day and age, just about *everything* is a computer.
What's the difference between a $299 stand-alone dedicated
client and a $399 computer besides 33% higher cost?
A practical wireless audio distribution solution should really cost not much more than
a couple of hundred bucks total. That's an assessment I've made myself about a product
being realistically priced on the market. It'll drop with time of course but early
adopters will pay a bit more for leading edge technology.
And the OP *doesn't need* or *want* a computer simply to hear music ! - never mind the
fact that they crash all the time and add acoustic noise ! You need a simple
standalone solution that you plug in and it works. Not a definition of a PC by any
means !
Remember - the alternative is a piece of screened wire !
http://configure.us.dell.com/dellstore/config.aspx?c=us&cs=19&l=en&oc=D30CL1&s=dhs
I believe the OP said:
"Is there a wireless solution to distributing audio
throughout a residence to
8 rooms? Digital?"
One approach is to have a file server loaded with audio
files that are to be distributed. Clients at each location
download the audio that is desired at that location.
Who said he was using a *FILE SERVER* ? What about simply putting a CD into the CD
player. Most ppl still do this you know !
Another approach is to have intelligent clients that stream
audio from off-site services through an on-site router.
I believe the OP said nothing about the wireless connection
being necessarily slow, given that the wireless connection
was generally available for a reasonable cost.
The OP merely speculated about wireless links.
But a distributed solution running 16 bit linear PCM can be
assembled from inexpensive computers.
How may ppl actually *want* their homes polluted with computers to do simple tasks ?
They are big, ugly, unreliable, noisy, quite expensive even now and use lots of power.
OK, someone puts together a Linux box and some software.
Someone has finally got their act together it seems.
http://www.wirelessnetdesignline.com/products/57700997
Oslo, Norway— Nordic Semiconductor introduces the nRF24Z1, a complete digital wireless
audio streamer solution in a 6x6mm package. The device uses the company's 4Mbit/s
MegaZtream platform with an embedded Quality of Service (QoS) subsystem, a low power,
robust 4Mbit/s wireless 2.4GHz transceiver, and all appropriate digital audio
interfaces.
Designed for wireless audio streaming applications, the nRF24Z1 is optimized to
operate in the presence of potentially disturbing sources such as WLAN, cordless
telephones, and Bluetooth. The RF transceiver portion is designed to ensure that there
is bandwidth enough to stream and transmit 16-bit 48Kspls/s CD quality audio without
using compression. In addition to streaming audio, the nRF24Z1 also features a digital
control information channel for transfer of control information such as volume,
balance, track and display information.
Some key audio features include: I2S serial connection for glue less interface to
virtually all audio chipsets as well as low cost A/D and D/A for analog audio, S/PDIF
interface for direct digital connection to PC and surround receivers, input supports
audio up to 24 bit 96Kspl/s directly, output supports audio up to 16 bit 48kspl/s
directly, and programmable low 2-18ms link latency
Suited for use in portable as well as stationary equipment, the chipset is specified
with 5mA average current (streaming MP3 data @ 192Kbit/s) and 15mA average current
(streaming LPCM data @ 1.5Mbit/s). The nRF24Z1 is sampling. Volume production is
scheduled for April 2005. The nRF24Z1(TM) is priced at USD $4.00 in 10K quantities
Graham
