The op-amp used was modified to have a low output resistance. As I told you a buffer might be needed if you can't find an op-amp with enough current handling capacity.
Adam
Adam
The buffer needs to be what is driving the load. Think of inserting it inside the op-amp and the output of the buffer now being the output of the op-amp.
Adam
If you did, you did not tell us about it here. You mentioned trying two different opamps, one that could deliver a max of 50mA and the other that could deliver a max of 200mA, and then you complain that you cannot get 1A.
Find a Audio Power Amp (which is NOT the same thing as an opamp) that can deliver at least 20W into an 8 Ohm load and it will work.
