I’m currently starting a project that may need high power drawing from a battery.
First thing, the battery is a 18490 from AW, which nominal voltage is 3.7V. The battery runs from 4.2V at full charge to 2.5V when discharged. It is also capable of a continuous 18A draw.
I need to draw at most 10A from this battery, but regulated at 5V (if possible, from 4.2V to 3V, I don't want the battery to discharge too much.).
AND as I am quite a noob in electronics, I need your help finding an IC or whatever could allow me to achieve this.
There’s however a restriction, this whole circuit must be small enough to fit on a 19mm in diameter circular board. (That's why it is so difficult to me to find a solution)
Any help would be greatly appreciated !
