Scrapping the MOSFET idea due to static sensitivity, I would like to use a N channel BJT to turn on/off a circuit. The base will be taken high by a pic output. With some testing tonight using a S9018 transistor, I found that by biasing the base with various resistances, I was able to get different voltages across the collector and emitter.
With Vcc at 2.97VDC using a base resistor of:
3k0 = 2.350V was measured between the collector and emitter
4k7 = 2.517V
6k8 = 2.620V
7k5 = 2.660V
8k2 = 2.680V ~320μA
So very little current was required to saturate the base and diminishing returns are seen past 8k2 resistance. Actually using a trimpot at 10k resistance, my circuit ceased functioning... not sure why (perhaps not enough current?).
Questions:
Thanks in advance!
4k7 = 2.517V
6k8 = 2.620V
7k5 = 2.660V
8k2 = 2.680V ~320μA
Questions:
- What governs the voltage drop seen between collector and emitter? What values can I compare on the datasheet to find a more efficient BJT? I am reading a loss of about 0.29VDC.
- What values on the datasheet are responsible for determining the current necessary to saturate the base? If I wanted to saturate the base using a smaller current, how could I find that transistor?
Thanks in advance!
