G
Glen Walpert
Sounds like metal migration which is a completely different kettle than
wetting.
Metal migration is a surface phenomenon, not a bulk phenomenon like
diffusion. The term "wetting" does imply a liquid being involved, when
solid metals are involved it is generally referred to as forming a
metallurgical bond, as is the case in the silver-bonded seal rings.
Yes, quite like corn starch and water. ...and the shape of the "beads"
changes the characteristics of the paint (directionality of the shear).
I'm still not buying the "solid" part.
I don't blame you for not buying the "solids wetting" part, but there are
lots of examples of solid to solid metallurgical bonds made with no
melting, including fabrication of bi-metal sheet by pressure bonding
between rollers, explosive bonding of heavy bi-metal plates, and the
fabrication of aluminum evaporators for refrigerators, where a pattern
for the integral tubing is printed on one clean aluminum sheet, two clean
sheets are pressure bonded, and then the unbonded tube pattern is
hydraulically expanded.
