On 30 Oct 2004 13:41:31 -0700 "alcarski"
used 7 lines of text to write in newsgroup: alt.security.alarms
Using Vista128BD,multiplex.
Puts in way me oneself event reset system, code 305.
So as at damage of power supply.
Resets clock
What this is?
How on this to advise?
Help,alcarski
Setting the Time and Date
To set the real time clock, perform the following steps:
1. Enter Installer or Master Code + [#] 63.
The day of the week is automatically
calculated based on the date entered. Time
and date entries are made by simply entering
the appropriate hour, minute, month, day
and year.
Press [*] to move the cursor to the right of
the display, to the next position.
Press [#] to move the cursor to the left of the
display, to the previous position.
2. Enter the correct hour. Then press [*] to
move to the "minutes" field.
3. Enter the correct minutes. Press [*] to move
to the AM/PM position.
4. Press any key 0-9 to change AM to PM, or
PM to AM. Press [*] to move cursor to the
"month" field position.
5. Enter the correct month using a 2-digit entry.
Press [*] to move cursor to the "day" field
position.
6. Enter the correct day using a 2-digit entry.
Press [*] to move cursor to the "year" field
position.
7. Enter the correct year.
Press [*] to continue.
8 The following display appears:
Broadcast Time?
1=YES 0=NO
If panel linking is being used, enter 1 (YES)
to send this time and date setting to all the
other panels. Otherwise enter 0.
Press [*] to exit the real-time clock edit
mode.
-Graham
Remove the 'snails' from my email
