NE555 reset pin using transistor
bertus
Hello,
How do you trigger the sensor?
Is the magnet strong and close enough?
Do you see the led change when the magnet is close to the sensor in my schematic?
Bertus
Alright, I just found out that when sensor is connected on pin 4 and to gnd through 1k rezistor it's triggering some safety feature on it. So I will try different one. Or has someone any idea how to bypass it?
Hello,
Bertus
I'm using diomidium magnet or how it's called in english. Yeah it's strong. Problem is some safety feature on sensor. I don't see led turning on, when measuring with multimeter, sensor is just off, until I turn of and on circuit. I had this exact issue with my first design. I thought it had to do with flyback current, but I guess I was wrong. I will try linear sensor, but I didn't want to use, because its linear and in my application, there is more then one source of magnet pole I can say?
bertus
Hello,
Looking at the datasheet, the sensor latches until reverse magnetic field is given.
Bertus
  • ss30at-ss40a-ss50at_latching_hall sensor.pdf
