I'm working on a simple project with off-the-shelf modules, that will add volumteric control to a home espresso machine (what this essentially does is use a hall-effect flow meter on the tank-to-pump pipe coupled with an electronic timer relay (in counter mode) that counts the pulses from the flow meter, stopping the coffee machine at a preset count). Simple...
However, whilst this all starts very nicely when the 'brew' switch is hit - and the machine stops automatically at the preset point - the electronic timer relay then needs to be manually reset (by hitting a "reset" button on it). I'd like to avoid this if possible, but I can't think of an easy way to do it.
What needs to happen is:
1. There's a 240V circuit that drives the pump, that's switched on when the brew switch is on - I'd like to use this as the initial trigger. There's then a pin on the timer controller that, when connected to +12V (another pin) momentarily will reset the counter (as if 'pushing' and releasing a momentary push "reset" switch)
2. So, when this 240V circuit is switched on, I'd like a separate 12V circuit to go on briefly and the off again - and remain off (until the 240V is switch off, reseting the circuit).
With my very basic knowledge, I'm assuming that there's going to be a 240V relay that, when energized, will switch the 12V circuit - but I only want that 12V circuit to remain on very briefly (perhaps 0.1s) and then switch off again.
Can anyone help me with a relatively simple way to do this, and avoid having to manually press this "reset" button all the time?
Many thanks for any help or advice that anyone can offer.
