John B
I disagree. Emitter follower has a different topology. There is nothingEeyore said:The more common name for this is an emitter follower.
"below" the collector, of my flipped transistor, other than an attached
ground.
If this npn transistor were to be suddenly replaced by a pnp, then I see an
emitter follower. Of course, the controlling signal at the base would then
have to be referenced to the upper rail, instead of to ground, as my npn is.
It inverts voltage. When the base voltage rises, more current flows downAbsolutely not. Common emitter is inverting though.
into the emitter from the upper rail, through a load, and out through the
collector to ground. The voltage at the emitter pin goes down, not up.
An emitter follower is non-inverting. This is not an emitter follower.
Granted.
No - wrong. Beta hasn't changed and this configuration does indeed have current
gain.
It's Beta reverse...as attested to by so many other posters in this thread.
It's drastically different from Beta forward.
Not to be argumentative, but a c-b junction is forward biased in a saturatedNot much difference really. I can't ever recall seeing it specced in this
configuration. The c-b junction is always reverse biased anyway.
circuit that employs common emitter. Very common situation.
John B
