Henk van Winkoop
Hello,
I'm using the Agilent 34970A with module 34901A using the hardware Alarm
signals from the external 'RS232' connector to directly control some
hardware.
When using MEAS, to measure 4 temperature sensors, this command will use the
scanlist scan which will clear the Alarm signals.
To avoid clearing Alarm signals I thought bypassing the scanlist scan by
MONITORING the sensors one by one and then reading the monitor values.
Somewhat cryptic:
"ROUT:MON:STAT ON"
'---read-sensor-1---
"ROUT:SCAN (@101)"
"ROUT:MON (@101)"
"ROUT:MON
ATA?"
ShowMonitoredValue(@101)
'---read-sensor-2---
"ROUT:SCAN (@102)"
"ROUT:MON (@102)"
"ROUT:MON
ATA?"
ShowMonitoredValue(@102)
etc.
Now EACH single measurement takes about one second.
Is there a way to speed up the measurement time?
As when using a scanlist, measurement of ALL 4 sensors is executed within
one second.
Henk
hardware.
Somewhat cryptic:
"ROUT:MON:STAT ON"
"ROUT:SCAN (@101)"
"ROUT:MON (@101)"
"ROUT:MON
"ROUT:SCAN (@102)"
"ROUT:MON (@102)"
"ROUT:MON
etc.
one second.
Henk
