L
lbbss
Is it a good idea to put Vaseline on a coax connection, or will it
damage the thread? thanks.
lbbss said:Is it a good idea to put Vaseline on a coax connection, or will it
It won't damage anything, but it might be kinda messy. Is this connection
outdoors?
outdoors?
lbbss said:no its a indoor connection, but I have lots of them.
Michael Kennedy said:If it is a perminanent connection I don't see where it will be a problem.
Like someone else said silicone might be better, but I can't see why
vaseline won't work. Usually indoor connections don't suffer from the
corrison problems that outdoor ones do, unless say you live on the beach
and leave your windows open all the time.
Mike
Michael said:Oh to clarify I meant silicone grease.. Not RTV silicone sealant
Ian Jackson said:WD40's OK too.
WD40's OK too.
It won't vaporize completely. There'll be a long-lasting film leftPeterD said:OK for what? For short term water displacement yes, for anything more
than a week or so, WD-40 is totally useless, it is 100% aromatic, and
will vaporize leaving nothing.
behind -
especially if the connectors are indoors. However, Vaseline and
silicon grease will be just fine.
PeterD said:WD-40 *WILL* vaporize completely. That is part of the WD-40 design
specification! WD-40 is not, was not, never was, isn't, won't be a
lubricant for long term use. It has slight value as a short term
(hours or perhaps days) for lubrication or protection, but no value
for either for any period of time exceeding a day or two, let alone a
week.
damage the thread?
So basically it does not sound like Vaseline will do
any harm to the thread. That's all I needed. Thanks.
Unless someone, for a joke, has put iron filings in his favourite pot ofWilliam said:I didn't respond to this because I wasn't sure what the OP wanted to know.
I assumed he meant whether it was okay to grease the threads, but everyone
else seemed to interpret the question as to whether it was okay to cover the
outside of the connector with Vaseline -- which seems harmless.
If you were greasing up the threads to keep them from binding -- would the
goo have any effect on the electrical behavior of the connectors?
