Van project fm and ir headache please help
newbie here
So I’ve fitted a had flip down monitor in my project van
It gives out fm or infrared audio signals no audio out cable
I’ve fitted a small,personal fm radio next to the monitor with an audio jack going from the headphone jack to a Bluetooth speaker with aux in
Relieves the signal,but a lot of hissing not very good when a film is on
They sell it headphones so my question is
Is there an ir receiver with output jack or could I somehow adapt a set of headphones somehow so can use the speaker don’t want to use headphones
Thanks in advance hope someone can help
because i want to be able to listen to the radio or usb seperate from the rear tv bit if that makes sense
so kids can watch films while i drive to music
There's absolutely no reason why you can't connect wires to the speaker(s) - via a suitable resistive divider to get the signal down to the level required by the audio input (amplifier).
If you're not interested in the headphones at all then take them apart down to the component (board) level and repackage it to suit - even encasing it in heat-shrink and stuffing it behind the radio would do!
So
If I striped the headphones out
Would it work if I disconnected the wires from the little speaker inside and connect the wires to a jack plug then into the Bluetooth speaker
If so say red and black on the speaker which colour to where on the new jack plug
Depends on the main audio driver really - some are bridged outputs and some single-ended - but, yes, that's the basic principle.
The red wire would go to the tip, the black to the sleeve (of the jack plug) - you might have to short the two 'tip' connects to get a mono signal.
If you could post a close-up image of the audio board from the headset we could determine what type of output you have and whether or not additional parts are required (usually a simple blocking capacitor).
