I was asking if plate-load resistors have an analog in transistor-mediated circuits.
The original answer to this has been moved (along with the discussion about how many Ohm's can dance on the head of a pin) by request to here:
https://www.electronicspoint.com/ohms-law-not-ohms-law-question-t252367.html
The non-controversial answer is that yes, there is an analogue in circuits using transistors. Where the load is a resistor, that load may be placed in the collector (or drain for FET's) circuit so that the change in current through the active device (valve, BJT, FET, etc) is converted to a voltage swing across the load (or load resistor).
