It is possible that, knowing the diode characteristic parameters of the 1N3210 (
datasheet), you could use a parametric search engine such as
this one on DigiKey to find a suitable equivalent. If you use Google to find the
1N3210 on DigiKey, the splash page gives the important diode parametersunder the heading
Product Attributes, but perhaps more important for you is a clickable box labeled
View Similar near the bottom of that listing. This will lead you to a
DigiKey page with some 56,123 diodes. Narrow your search by choosing appropriate parameters from the menu choices at the top of the page. For your application, the peak inverse (reverse) voltage or PIV capability and the forward current capability are probably most important, followed perhaps by packaging and temperature range of operation.
I am really glad for you that
@KrisBlueNZ was able to help you find a durable solution to your contact erosion problem. He is sorely missed here in the forums, but the hundreds (if not thousands) of well-designed solutions he provided here will be his legacy on ElectronicsPoint. Nothing ever dies on the Internet. Once posted, it is there forever.
I don't know which Square D pressure switch you are using (they make a lot of variations), but the diaphragm-operated, adjustable pressure range and adjustable hysteresis, two-pole, single-throw version I use on my well and aerator pumps here in Florida fail about once a year when ants sneak under the plastic cover and wind up being killed under the contacts. The resulting ant goo is not electrically conductive.
I don't know what ants find so attractive about the innards of this pressure switch. I can clean the contacts with a fine abrasive and restore functionality for awhile, but the final solution may be to apply a silicone RTV (Room Temperature Vulcanizing) sealer over all the possible entrance holes. If I never have to adjust the pressure switch cut-in and drop-out pressure points, the Square D pressure switch could outlast my thirty year mortgage with "bullet-proof" sealing against ants.
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
