Using 74xx574 D FF to expand PIC outputs
Peter S. May
Greetings. I'm having a problem that reaches beyond my basic knowledge
of digital logic and electronics, and so I'm hoping an expert eye can
spot the mistake.
I'm working on a seemingly straightforward means of expanding the
limited outputs of a PIC 16F88 to 32 pins by way of four 74ABT574 octal
D-type flip-flops and a 2-to-4 decoder. The way the trivial design is
supposed to work is that each RBn pin of the PIC is attached to a
corresponding Dn pin on each of the four 574s. The program would assign
their data round-robin style, assigning one word to PORTB and then
clocking the destination DFFs using the demuxer. The outputs in this
experiment are LEDs run via 1K resistors (3 or 4mA).
I've had some problems, though, and they're somewhat spurious.
Sometimes, the outputs of the first 574 always echo PORTB; other times,
one or more of the 574s read correctly except for a split second of
flicker, which I'm guessing is a momentary read intended for another
output, but I have no idea why.
I've simplified the circuit to the minimum that should implement the
functionality, done away with the demuxer and three of the four 574s,
and the problem remains.
Here is the circuit:
16F88 74ABT574
| Vdd|--> +5V <-----|20 Vcc |
| Vss|--| GND |--+--|10 GND |
| | +--|1 /OE |
| | | | 1K LED
| RB0|--------------|2 D0 Q0 19|--/\/\--|>|---+--| GND
| RB1|--------------|3 D1 Q1 18|--/\/\--|>|---+
| RB2|--------------|4 D2 Q2 17|--/\/\--|>|---+
| RB3|--------------|5 D3 Q3 16|--/\/\--|>|---+
| RB4|--------------|6 D4 Q4 15|--/\/\--|>|---+
| RB5|--------------|7 D5 Q5 14|--/\/\--|>|---+
| RB6|--------------|8 D6 Q6 13|--/\/\--|>|---+
| RB7|--------------|9 D7 Q7 12|--/\/\--|>|---+
| RA4|--------------|11 CLK |
| RA5| ---------------
| RA6|
| RA7|
The same behavior is exhibited when the LEDs are reversed with cathode
on the output and anode on +5V. In theory, I should also be able to
switch the CLK of the 574 among RA4-RA7 to output any of the four
different output patterns, which would be functionally identical to the
full circuit. This does work, insofar as doing this echoes what each of
the 574s would have been doing before, but is subject to the same glitches.
I've tried adjusting the delays on the clocks (which shouldn't be
necessary; the 74ABT574 specifies a much higher clock frequency than I'm
using), not just with the nops in the version at the end of this message
but also plugging in an entire delay loop, and the problem remains. I
find myself wishing I had an oscilloscope!
The program follows. Is there anything in the program--or, more likely,
the circuit itself--that I need to try adjusting?
Thanks a zillion
PSM
The program:
errorlevel -302
include "hgt_16f88.inc"
processor 16f88
org 0
goto Start
org 4
ISR
retfie
Start
BUF0 equ 0x30 ; - 0x33
ADDRESSBUFFER equ 0x40
Setup
bsf STATUS,5 ; set bank 1
movlw b'00000000'
movwf TRISA
movlw b'00000000'
movwf TRISB
bcf STATUS,5 ; set bank 0
clrf PORTA
clrf BUF0
clrf BUF0+1
clrf BUF0+2
clrf BUF0+3
Loop
; The first two count forward and backward, respectively
incf BUF0,f
decf BUF0+1,f
; The third rolls one direction
rlf BUF0+2,f
btfsc STATUS,C
bsf BUF0+2,0
; The fourth rolls the other
rrf BUF0+3,f
btfsc STATUS,C
bsf BUF0+3,7
call SetExternalRegisters
call Delay
goto Loop
Delay
COUNTH equ 0x20
COUNTL equ 0x21
movlw 0x00
movwf COUNTH
movlw 0xDA
movwf COUNTL
Delay_Loop
; 16-bit decrement
; 9 instructions per loop
; Time taken = 9 * 4 / osc speed
; For 31.25kHz, 868 = about 1s.
decf COUNTL,f
incfsz COUNTL,w
incf COUNTH,f
decf COUNTH,f
movf COUNTL,w
iorwf COUNTH,w
btfss STATUS,Z
goto Delay_Loop
return
; Manual version!
movf BUF0,w
movwf PORTB
nop
nop
nop
nop
bsf PORTA,4
nop
nop
nop
nop
nop
nop
nop
nop
bcf PORTA,4
nop
nop
nop
nop
nop
nop
nop
nop
movf BUF0+1,w
movwf PORTB
nop
nop
nop
nop
bsf PORTA,5
nop
nop
nop
nop
nop
nop
nop
nop
bcf PORTA,5
nop
nop
nop
nop
nop
nop
nop
nop
movf BUF0+2,w
movwf PORTB
nop
nop
nop
nop
bsf PORTA,6
nop
nop
nop
nop
nop
nop
nop
nop
bcf PORTA,6
nop
nop
nop
nop
nop
nop
nop
nop
movf BUF0+3,w
movwf PORTB
nop
nop
nop
nop
bsf PORTA,7
nop
nop
nop
nop
nop
nop
nop
nop
bcf PORTA,7
nop
nop
nop
nop
nop
nop
nop
nop
; Show a pattern that means "this isn't right"
movlw b'11000011'
movwf PORTB
return
org 0x2007
CONFIG1
; Use internal oscillator at 31.25kHz
dw 0x3f10
end
i cannot inagin why would you dlay the clock add a ,1mfd across the vcc chip and make sure your gnd is solid no gnd loops. without a scope it is try and try forever.
