I can't believe it's been nearly two years.... Well, stuff happens. Anyway, I have to report: SUCCESS
Thank you, Dave9. I could not have done this without all your advice.
After getting my soldering station, I bought a Solder Practice Kit (ELENCO, Model SP-3B). This was a terrific way to improve my soldering skills as well as introduce me to various components, terminology, etc. There was nothing, however, that mimicked the small size of solder joints I needed to create; those pins are only about 1.2 mm long x 0.3 mm wide. Here's a photo of my prep after using JB Weld epoxy to secure the mini connector:
I bent the (left-to-right) 4th pin up and out of the way. I did want to connect the #2 & #3 data pins. Skinny little traces for those... I chickened out using a Harbor Freight heat gun with soldering paste. I soldered the outside pins conventionally without much difficulty. Those middle two pins were another matter. I tried to apply soldering paste and the swipe with the iron; got a nice little trace adhesion on pin 3. I ended up trying to hand solder pin #2; I thought it was a disaster, and I couldn't remove the solder to give it another try. But, I figured I'd see if the bluetooth speaker would work before messing with it any more. I attached my power cord and the red LED lit up! I was getting some intermittent disconnection, so I soldered the two tabs of the connector to the PCB; improvement. The speaker and my iPhone seemed to pair, got the typical connection chime. But my iPhone reported failed connection. I figured those data pins were shorting out, being connected (apparently by a big gob of solder), preventing proper connection/handshaking of the bluetooth protocol. I was about to fire up the iron and work on it further, when I realized that I selected the wrong bluetooth speaker on my iPhone! No wonder I failed to connect. I did connect without difficulty, played a few songs, changed songs, adjusted volume. It's good. Here's the post-solder result. I'm surprised the speaker works:
I suppose that job looks somewhat laughable to you guys, but those pins and traces are very small. Anyway, I'm pleased. If I had to do it all over again I'd use paste for all connections and use the big heat gun (saw a YouTube video). I'll probably buy some other small kits and continue with this. Next up, however, is replacing the wiring harness on a guitar; should be easy with the required "macro" solder connections (vs. what I've been doing lately).
Thanks again, Dave9
Thanks again, Dave9
