Unlabelled and disconnected mains primary wires
G
Grant
My understanding of the term autotransformer is primary and secondary
electrically continuous, ie no electrical isolation
You're not looking for answers, are you?
Grant.
Phil Allison
"Nutcase Kook is So Full of Shit "
Does anyone have the generic name for these wasteful construction made in
or
for USA , for export kit ? the ones with a (electrically) continuous
single
primary winding
** Wot a load of utter bollocks
Most audio amps made in the ** UK ** between the mid 1960s and late 1990s
had
multi-voltage, single winding AC transformers.
Check any old schem from Marshall, Vox or Sugden etc, et alia.
http://www.audiomisc.co.uk/JES/A21series2/A21series2.html
http://www.schematicheaven.com/marshallamps/jcm800_lead_mstvol_50w_2204.pdf
http://www.schematicheaven.com/voxamps/ac301960.pdf
http://www.schematicheaven.com/voxamps/ac151960.pdf
Nutcase Kook is Soooooo... Full of Shit
..... Phil
Phil Allison
Nutcase Kook is Sooooo Full of Shit
You can have multitaps on dual primary ones for variants on the theme of
110/240V, so not an exclusive term
** Nutcase Kook is Sooooooooooooo Full of Shit !!!
..... Phil
David Nebenzahl
He rarely is. Just sitting at the bar bending the ears of whatever poor
saps sitting nearby are willing to listen to his ramblings.
Cydrome Leader
N_Cook said:
http://www.slpower.com/Upload/Technical/20070404102642455201154_41-32512F_ML
_Series.pdf
That transformer type is the 2 separate primaries, not the subject of this
thread.
Does anyone have the generic name for these wasteful construction made in or
for USA , for export kit ? the ones with a (electrically) continuous single
primary winding
You're right- they must have just cheapened their transformers. Condor
stuff used to have the 5 terminal primary windings. If you can find a
manual for an older generation "international linear power supply" how
those windings are setup is diagrammed.
They're not a single winding though, and not nearly as wasteful as 50Hz
mains frequency when it comes to excessive use of materials and size.
