I did some research on google about connecting unequal power sources together and I need some advice. I have two unequal power sources and I want to connect them in parallel to increase the current but both voltage are not equal. I've read that the higher voltage source would leak towards the lower source causing some kind of internal damage. Would this solution work? Or is there a better one?
Build two SEPIC converters for each power source and boost/buck both supply to the same voltage and then connect them in parallel.
