Unequal size Li-Ion batteries in series?
Thomas David Kehoe
Is it possible to use two rechargeable Li-Ion batteries of unequal sizes in
series?
I'm designing a device that will run at 4V, 25-30mA. The device is pager
size so a 9-volt battery is too big. I thought I'd found the solution in RC
car batteries. These are flat so they can lie on top of the circuitboard.
They are polymer li-ion, 3.7V. They are available in two sizes: 750mA and
170mA. Two 170mA batteries lasts only 7.5 hours. I need at least 15 hours.
The case can fit one large battery and one small batteries, or two small
batteries. Possibly I could fit one large and two small, or three small
batteries.
I set up one large battery and two small batteries in series. The voltmeter
read 11.9V. I set up the device and came back ten hours later. The large
battery was at 4.1V - fresh - and the small batteries were at -0.1 volts.
They had puffed up. I charged them but they never went over 0.1 volts. How
could the large battery be fresh and the two small batteries be destroyed? I
can't figure out a way to measure current draining from each battery.
Now I have two test devices running. Each has one large and one small
battery, in series. The difference is that one device has the large battery
connected to the positive terminal and the small battery to the negative
terminal; the other device has the small battery connected to the positive
terminal and the large battery connected to the negative terminal.
Any other suggestions?
mc
I think by mA you mean mAH throughout.
If you put unmatched batteries in series, one will discharge first, and then
the other one will reverse-charge it by continuing to drive current through
it. With NiCd cells this causes immediate severe damage. I'm not sure
about Li-ion, but it sounds from your description as though the results were
equally fatal.
mc
BTW, if you needed 4 volts, why did you put them in series? Was 3.7 V not
enough?
In parallel, batteries of matched *voltage* are OK, regardless of whether
the capacities match. The strong ones recharge the weak ones, rather than
reverse-charging them. But if one battery shorts or becomes electrically
leaky, it will discharge all the others.
The 3.7-volt, 750 mAH (if it's mAH) battery will supply 3.7 V to your 30-mA
load for about 24 hours.
If you need technical assistance with your design, please drop me a line (mc
at uga dot edu). I'm in speech science myself.
W
Watson A.Name - \Watt Sun, the Dark Remover\
series?
batteries.
You've already found out the hard way that the small battery won't work.
If you must have a certain voltage, you should use a V converter to
boost the single large cell up to what you need, and skip the multiple
oddball cells.
Peter Bennett
series?
No - in general, it is a Very Bad Idea to use batteries of different
capacities in series, as the lower-capacitiy battery will become fully
discharged before the higher capacity one, then the higher capacity
battery will start to reverse charge the low capacity one..
batteries.
What was the current drain? If it was 30 mA, your 170 mAH batteries
would be fully discharged in about 5.6 hours, while the 750 mAH cell
would be good for about 25 hours.
The order of the batteries doesn't matter - the 170 mAH cell is only
good for 5 hours, regardless of where you put it.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
mike
series?
batteries.
Do NOT charge or discharge equal lithium ion batteries in series without
some monitoring circuitry to keep 'em from doing what yours did.
NEVER, EVER charge or discharge unequal lithium ion batteries in series.
Equal means same part number, same history, same batch.
You don't want to do that with ANY battery technology, but at least
other technologies are LESS likely to explode when you do. I said LESS
LIKELY...
If you intend using lithium cells, you need to do a LOT of reading on
the subject. The Cadex site is a place to start.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Wanted 12" LCD for Compaq Armada 7770MT.
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
E
ehsjr
Thomas David Kehoe wrote:
I
Others answered about the setup you have - don't do it.
But say you had a series setup with identical batteries.
To measure the current draining from each battery,
just measure the current draining from the series
combination. The current flowing in each battery is
the same.
Yes - since you are designing the circuit, why not design
it to work from 3.7 volts instead of 4 volts? Otherwise,
a DC-DC converter, as Watson suggested. These days they are
unbelievaby simple - a chip and a few components.
Ed
