Richard Crowley
Yes, and all your base are belong to us....;-)
An excelent summary of the troll. )
I'm done.
... It would
also be helpful to reveal WHY you are asking so maybe
we can figure out WHAT you are asking.
"Radium" wrote ...
Sony XDCAM HD. Don't try to read the price while standing.
Radium said:Bob Myers says in http://groups.google.com/group/
sci.electronics.basics/msg/bbad436d1cb6cd02?hl=en& :
"RGB simply means "red, green, and blue" video - it clearly can be
represented in either analog or digital form."
What is the most common type of uncompressed digital video? Is it a
type of PCM format? If not, what is it and why isn't PCM video -- like
the PCM audio in CDs -- used?
the difference between those different video compression formats is
roughly analogous to the difference in the various audio compression
formats that you claim are "all PCM". so i guess all video is PCM,
from your definition.
Radium said:Would you mind naming one?
Radium said:Hm. Maybe using a bigger disc [about the size of 33-speed phonos] and
400 nm recording/playback lasers [instead of the dirty old red lasers]
would solve the above problems.
Richard Crowley said:D1 & HDCAM SR were uncompressed component digital video formats.
D2 and D3 were uncompressed composite digital video formats.
All were tape formats, and none was terribly popular nor
did they last very long.
There are some high-end schemes for recording uncompressed
video used in digital cinematography. I believe they are all
hard drive-based, not tape or optical.
The SDI digital video interconnection scheme used in
broadcast facilities has at least one mode that will
transmit uncompresed (4:4:4) video.
Richard Crowley said:"Radium" wrote ...
Sony XDCAM HD.
What does "type" mean in your world?
By "common" do you mean historic or current?
It is likely not defined that way because PCM is usually
used to refer to audio, not video.
What does "PCM video" mean in your world? Does it
just mean "digital video"?
nappy said:Gene E. Bloch said:Uncompressed Digital Video vs. Uncompressed Digital
Audio>,
On 2/12/2007, Frank posted this:
Audio>,
On 2/12/2007, Carlos Moreno posted this:
Elan Magavi wrote:
Yes, that is what the OP said. Your reading is excellent.
[...] You're writing is excellent.
Too bad that the same can not be said about you're's... ;-)
Carlos
I think your wrong.
That should be: I think you're wrong.
As in, "I think you are wrong"; "you are" contracts to "you're".
In fact, the same can be said about hi's
Or is it his'?
Oh, I *hate* apostrophes!
Whatever happened to basic education in this country?
No wonder what's her name's baby is the hot news story of the month.
Whatever happened to the idea of humor in this country?
In case you didnt' catch on, m'y response was further satire in response
to Fran'ks satire
I know that, Gene!
Well, then, you are much too subtle for me
I think your both beeding a dead herse here.
Richard Crowley said:DVCpro50 is compressed 2.5:1
Of course, we have to wonder where "Radium" thinks he
can get access to any "uncompressed video". I seriously
doubt that he has ever seen it (or likely ever will in his
lifetime.)
Okay, but it's hardly uncompressed. XDCAM HD is yet another lossy
compressed, long-GOP, interframe-encoded, temporally and spatially
compressed MPEG-2 format.
XDCAM HD is the poor person's HDCAM, but great for news organizations
capable of adjusting to an IT-based workflow. And the discs ($29.95
each at B&H) are cheap enough to store on a shelf for archival
purposes if necessary.
Bob Myers said:OK, I'm a practitioner. What answer do you think I should
give?
Of course they will - but that doesn't mean that there aren't other
interfaces that carry video around in RGB form. What SHOULD
I call the color encoding on DVI, if not "RGB"?
Arny Krueger said:It's just a matter of who do you talk to - a practitioner, or a
theoretician.
If you walked into a room with a dozen A/V techs and said: "I have a RGB
signal", they'll think you're talking about an analog signal.
Richard said:I'd bet that "Radium" couldn't tell the difference between
XDCAM and true raw uncompressed video. I still doubt
that he has ever seen raw uncompressed video. There
being no way of delivering it to consumers.
Certainly not in the consumer arena and very rare in the
professional one.
