D from BC
I think I can convert an E core AC power transformer into a tattoo
gun.
If I sliced off the top of the E core, that would make two gaps. It's
now an electromagnet if I apply DC.
I'm going to also drill a hole down the center of the core.
This hole would be for the needle.
A spring is used to pull the needle up.
Magnetic force pulls a metal plate and the needle down.
I plan on driving the electromagnet with a power oscillator.
Questions
Will this work?
How big of a transformer should I hack up?.. I have a pile of all
sorts in the junk box..I'm guessing 20watts.
I don't mind taking the transformer to it's max temperature...whatever
that might be..
Any other design ideas?
For reference
http://en.wikipedia.org/wiki/Tattoo_machine
Actually I'm not tattooing.. It's to perforate 4mil vinyl.
I can't afford a laser.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
As I was writing this I came up with a better idea..
I think a needle stuck in a steel rod stuck in a solenoid might be
much easier to construct..
D from BC
gun.
Questions
Will this work?
that might be..
For reference
D from BC
