Platforms
Content
as a suggestion get some boards out of faulty DVD players, TV, monitors etc ... there is no shortage of SMD component
that you can experiment with desoldering and soldering back in ... great to experiment on and if you wreck something, its not a big deal
Youo will quickly learn how much heat is needed before components get damaged
Dave
I hope you didn't feel I came down too hard on you for your first SMD soldering attempt. Actually, it wasn't too bad for a first effort. But as others have said the key is practice, practice, practice. You have the right tools, flux and solder. A temperature controlled 60 W soldering iron for twelve bucks!? Outstanding! Your technique is correct, tacking opposite corner pins first. When you get the hot air gun, you will be able to re-flow solder and produce much nicer looking solder joints. It helps to have about a 4 or 5 diopter stereo magnifying headset and some really small tweezers. As @HellasTechn said, a flat-blade or spade tip will make for better heat transfer than a conical tip.Thanks. I had the chips and adapter boards so I decided to give it a go. I used about a 1.5mm conical tip. I applied paste flux and used flux cored solder. I applied a small amount to one corner pad then placed the chip on the board. After getting the first connection, I soldered the opposite corner and blah blah...
I am going to get a hot air gun sometime. I have a cheap one in mind. We'll see if it does the job. But for now I will have to rely on pencil types.
This is the iron I used: Solder Iron.
This is the hot air gun I am going to try: Hot Air.
Please let us know how well the hot air gun performs. Forty-five bucks and change sounds like a very good price. I have been looking for a soldering station with hot air and vacuum for SMD board re-work, but all I've found so far cost several hundred dollars, upwards to several thousand if equipped with fancy board holders and bottom heaters and other do-dads for production work.
