Arouse1973
Adam
Depends if they limit the speed of the connection from different data packages. Ask them to reset your bandwidth, tell them it seems restricted.
Doubtful , I really hate to say that the lag you are experiencing is caused by the 'latency' of the type of internet connection you have if it really is satellite..As it turns out, it was a Wildblue issue after all. We upgraded our package yesterday from the 10 to 30 Gig package. We at the time of upgrading had only used 20% of our data. I am on the phone with them now, and they tried to tell me we had already used up our data and were at 33 Gigs, apparently from yesterday to today we used all of that. He quickly saw the error, but is unsure of how to fix it, so I have been on hold for about 10 minutes while he is trying to get his supervisor to fix their own issue.
After they set the data back to the performance it should be, do you think that will fix the problem?
That should affect download/upload speeds... which should certainly match the plan details that are being paid for... but may not do a thing to the ping times / latency...Depends if they limit the speed of the connection from different data packages. Ask them to reset your bandwidth, tell them it seems restricted.
Depends on the ISP, they could have changed the routing instead of simply adjusting the throttling .When I upgraded from 20 Mbps to 50 Mbps my ping rate substantially changed, I would be surprised if it didn't up to a certain amount.
Adam
Latency for satellite connections is very high due to the distance the satellites are from earth. One-way systems typically get pings in the 400-500ms range with 450ms about average and two-way systems in the 690-1150ms range, with 850ms about average.
I sure as heck hope an ISP is not using that to limit clients....Yes agree, I don't think it's going to bring it down to 20 ms but it may help. I read that if you use Net-limiter and cut your bandwidth by half your ping will go through the roof.
Adam
Do a single PS4 game update and your monthly bandwidth allotment is eaten up and then some.try using 4g internet, tethering is supported on most android phones.
23 Gigs in a day is expected actually... PlayStation and Xbox can download that much in a single sitting if it's downloading a game or a number of updates. Do they offer a method for you to look at your current usage? Usually Service Providers will let you sign into a web-panel to view your current usage. You could argue against your usage unless they can provide you with the actual data they see, or some other form to monitor you usage.After talking with Wildblue, I must say that was a painful experience. They were all confused at what we were doing. I was switched from someone waiting on a supervisor, to randomly connected with a very rude supervisor who had no idea what was going on and said we used 23 Gigs of data in less than 24 hours and there was nothing they could do.
They are charging us $151.90/mo. for garbage. Then proceeded to tell me that with their internet I would always be a few seconds behind in first person shooter games no matter what I did because their internet did not support it, but that it would be great for any other online games. Like what? I have no idea.
They also said my ping of over 600ms was perfectly normal and had nothing to do with my lag in game. Complete garbage left and right.
Trying to find new service now, but living in a rural area there isn't really any options.
Has anyone heard anything about Windstream? Basically my options are Wildblue and Windstream I think.![]()
Great idea though to use in a pinch. A cell phones internet connection can be shared, and latency is usually really good.
Just keep an eye on date-usage. It should be very light usage for 'playing', but updates and 'voice comms' will eat it up.
