Baronvonrex420
I want to use the outputs from a 7 seg driver (74LS47 OR 7447) to light a LED
display AND to send a larger current (12vdc) to an LED array. Each seg of the
array is comprised of 6 LEDS, 2 strings of 3 in series. I would assume I
couldn't do this with the driver IC alone.
What is the best way to accomplish this? Triac, Transistor? Cost is a major
factor.
Also, please explain how I would route the pins, for instance, base to driver
emitter to ground, collector to power? Any additional components required such
as resistors or caps?
I need to get this project completed, so apologies in advance for the
newbieness!
Thanks,
Greg
http://www.rts-group.com
factor.
newbieness!
Thanks,
Greg
