dgleeson422111
Hello All
We have a problem with the a TRIAC device we are using.
We are using it to switch 230V AC mains on and Off.
The gate is connected directly to the output of our Attiny processor.
The whole cct is at mains level with + 5V generated from the mains for
the processor.
THE PROBLEM: using a lead from the PSU to the gate of the TRIAC we can
turn the device (and the mains) on and off. we cimply connect to +5V
for on, disconnect for off.
HOWEVER, with the processor we can turn the device on but not Off.
On investigation(circuit with gate connected to processor) we find
that on the gate we have a component from the mains, roughly at 0.2V
peak. This appears to be coming to the gate through the other mains
connected pins on the device. This mains component is capable of
keeping the device on. The pull down capability of the ATTiny
processor is poor and is having little effect on this mains component
on the gate.
the device is a 2N6073 from On Semi
http://www.onsemi.com/PowerSolutions/product.do?id=2N6073A
Should I be using an isolated gate TRIAC? or is there some solution to
removing this component getting on the gate.
Many thanks for any responses
Denis
__________________________
http://www.CentronSolutions.com
the processor.
on the gate.
Denis
